User | Kudos |
3 | |
3 | |
2 | |
2 | |
2 |
Let's have the following standard situation:
It happens quite often that you accidentally start dragging the class in the project window and sometimes you drop it outside of the containing lvlib. Now if you don't realize what has just happened, you drag-and-drop the class back inside the lvlib and save everything. Which means you've just lost the mutation history data and cannot load your persistent data any more. This is extremely dangerous (unless you have a quite fresh backup of your class).
I suggest that a serious warning message is popped up every time a class mutation history is about to be destroyed.
