- NI Discussion Forums
- NI Idea Exchange
- LabVIEW Idea Exchange
- The ability to move or switch items in the connect...
Announcements
The ability to move or switch items in the connector pane
A great time saver would be if we could drag or click to switch connections directly in the connector pane instead of having to disconnect and reconnect controls.
This can be a simple two click process:
If there's already another control\indicator where you click, they get switched.
Comments
- Comments (1 - 10)
- Next Comments (11 - 11)
In addition, we should also have the following shortcut:
<Shift>-clicking a used connector should disconnect it
(faster than right-click...drag down...overshoot...drag up...select "disconnect this terminal"...release mouse...).
it would be nice to be able to select the control then the connector pane
You can do this if you explicitly set your tool to the wiring tool, but I never bothered. I agree it's annoying, though.
Since most controls probably don't have a third common action, it would probably be useful if Ctrl could change to the wiring tool, but since I don't use that feature (Shift and Ctrl to get secondary operation) either, I doubt it would be worth it.
A nice compromise might be that if you have a single selected control on the FP and you click on an empty terminal in the connector pane, the control gets associated with that terminal.
- Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
- If your idea has not been submitted click
Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea. - Watch as the community gives your idea kudos and adds their input.
- As NI R&D considers the idea, they will change the idea status.
- Give kudos to other ideas that you would like to see in a future version of LabVIEW!
- Macro in LabVIEW
- Block Diagram
- Moveable Case Selector Label
- Create graphs with multiple scales and a "drag cursor"
- Nested In Place Structure Chain
- VI Property "Set origin at top left corner"
- LTS (Long-term support) vewrsion of LabVIEW
- Hierarchy Find for Front Panel Object
- Compact Stacked Shift Registers
- Add CUDA support
muks
on:
Block Diagram
vt92
on:
Ravens Fan
on:
jlokanis
on:
Dennis Knutson
on:
Aristos Queue
on:
Aristos Queue
on:
muks
on:
Add CUDA support
Aristos Queue
on:
Get rid of automatic key navigation assignment
GregS
on:
IMAQ VI's should support all image types which mak...
- Analysis & Computation (34)
- Execution & Performance (147)
- HW Connectivity (18)
- Installation & Upgrade (28)
- Networking Communications (13)
- Third party integration & APIs (26)
- UI & Usability (807)
| My Profile | Privacy | Legal | Contact NI © 2010 National Instruments Corporation. All rights reserved. | | ||
