NI Home
Cart Cart | Help
You are here:
Announcements
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
JW-L3CE
Silver Boolean False State
Status: New
by Active Participant JW-L3CE on ‎05-04-2012 10:07 AM
Viewing this suggestion requires a bit of setup
  1. Forget you know what Silver controls look like
  2. Think about it from a user point of view
  3. Imagine a set of indicators including a sole boolean indicator show up on the screen. You have no comparison to other states of the boolean indicator.
Is it True or False?
My opinion is that the gradient and lighter shade of green makes the state a little ambiguous. Not too much ambiguity, but enough to give me pause. Decreasing the gradient and darking the shade a little should help.
Yes, I realize this is a property you can set. This is more of a suggestion for setting the standard.
(this suggestion aside, my compliments to the designer of the Silver controls)
Comments
by Knight of NI on ‎05-04-2012 10:31 AM
I agree that there should be more contrast. On some LCD displays the difference is too small for certain viewing angles.
Yes, as you said, if there are ON and OFF LEDs next to each other, we can tell what's what, but if there is only one indicator, the state is not entirely clear.
by Knight of NI on ‎05-04-2012 12:29 PM
I think one problem is the shadow in the lower half of the "on" state, which appears to be cast by an external light source. A self-glowing LED does NOT have a shadow on the lit face unless it is off or extremely dim compared to the room lighting.
The ON state should not have a shadow, but be uniformly bright. THe shadow is OK for the off state.
by Trusted Enthusiast on ‎05-05-2012 02:57 PM
I've been trying to come up with why it feels wrong to me. I couldn't put my finger on it. Yes. This is the reason! Even if this doesn't get fixed, at least now I know why it makes me confused.
by Active Participant JW-L3CE on ‎05-07-2012 07:08 AM
True, a LED will not have a shadow, but a rounded LED will have a brighter center.
Although, these don't strike me as LEDs. More like a circular OLED or EL panel, which wouldn't have a gradient.
I guess it just depends on what they are.
by Active Participant Christina_R on ‎05-07-2012 02:47 PM
We will consider these changes for a future version.
Just so you know, the indicator is in vi.lib\silver_ctls\Boolean and is called LED NI_Silver.ctl. So, you can easily change the default colors for your installation of LabVIEW, or make copies of the indicator with your own color combinations that you can add to your palettes.
by Proven Zealot on ‎05-08-2012 11:56 AM
While we are mentioning the shading of the LED one little thing has been bugging me about the direction of the external light source.  for the Silver LED it is directly from the top dead center.  All other Silver controls (Save the Round Color box which has NO shading) the externat light source is from about 11:00 O-Clock
by Active Participant Manzolli on ‎05-25-2012 07:54 AM
Yes, the shadow should be only in the Off state. Kudos to change to a change that make it more realistic and with better contrast.
Latest LabVIEW Idea Exchange Blog Posts
About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Idea Statuses
Top Kudoed Authors
User Kudos Count
131
88
76
68
68
