User | Kudos |
3 | |
3 | |
2 | |
2 | |
2 |
Currently, there is exactly one undo buffer for everything.
Scenario: I make a minor code edit,
... then run the VI to test if we get the correct result for a variety of control settings,
... and then stop the VI and decide that we actually don't want to make the code change (e.g. because the results are wrong!).
--> for some reason, we need to press ctrl+Z many (many!) times, because first we need to "undo" all the control changes during runtime.
I suggest that two undo histories should be kept, one for edit changes and one for runtime changes.
In the above scenario, pressing ctrl+z after stopping the VI would immediately start undoing the edit operations.
