User | Kudos |
3 | |
3 | |
2 | |
2 | |
2 |
I'm sure we've all been there - with so many toolkits and palettes available for LabVIEW (and sometimes many VI's/Functions within them) it's very easy to end up with a functions palette that's taller than your screen. So LabVIEW adds a scrollbar - it is not possible, however, for you to scroll through the palette using the scroll wheel on the mouse.
The current situation:
Using the mouse scroll-wheel will only scroll the front panel or block diagram - you cannot scroll through the functions palette using the mouse scrollwheel. I have tried this in LabVIEW 8.6, 2009 and 2010 and it has not yet been added.
The proposed solution:
If the mouse cursor is over the functions palette and it has a scrollbar - scroll through the palette instead of the block diagram/front panel.
Why?
Because it'll make navigating through large palettes with lots of functions or large numbers of palettes easier. It is also a natural habit of anyone seeing a scrollbar to use the mousewheel to scroll through the items.
