From 11:00 PM CST Friday, Apr 11th - 1:30 PM CST Saturday, Apr 12th, ni.com will undergo system upgrades that may result in temporary service interruption.
mniedernhuber
(Save last used folder, MRU) - > Rename "labview.exe" "labview.ini" to "labview_20xx.exe" and "labview_20xx.ini"
Status: New
If a user has installed more than one LabView (2009, 2010 and 2011) the last used folder
is in all version the same. E.g. if i open a VI in 2009 and close labview afterwards, the
same starting folder is used in another Labview version like 2010 or 2011.
This is caused by the MRU List from windows, not from LabView itself. To prevent this
it would be nice to rename the EXE and INI files like:
labview_2009.exe
labview_2009.ini
labview_2010.exe
labview_2010.ini
labview_2011.exe
labview_2011.ini
labview_2012.exe
labview_2012.ini
Now the MRU from windows distinguish between different EXE Names and each LabView version has it own last used folder.
(see also: Forum - Last Used Folder (MRU)
2 Comments
Yamaeda
Proven Zealot
It'd be even better if the registry key handled versions through sub folders or such, but this'd work.
Qestit Systems
Certified-LabVIEW-Developer
X.
Trusted Enthusiast
Trusted Enthusiast
It is actually worse than what you say: if you run two versions simultaneously and, say, open project X in folder F in version V1, then switch to version V2 and choose "open project", folder F will show up again (with of course no warning). That's potentially very damaging if you overwrite one version of a VI with another (and are not using a version control software).
Your proposal sounds a bit drastic to go around a Windows feature though...
For instance, it would break code that assumes that the app is called LabVIEW.exe (in Windows).
