User | Kudos |
3 | |
3 | |
2 | |
2 | |
2 |
It would be nice to add another dimension to the system exec.vi that gives the user the option to open up the “Run as Administrator” command prompt in Windows 7. This would enable a system administrator to use LabVIEW to make certain, currently restricted, changes to the computer. I don’t believe it would create a security risk because you have to be logged in as an administrator anyway to have the access rights
As far as I’ve seen, there really is no string that you can enter into the command line that will instruct an elevated command prompt to open. With this added functionality in the system exec vi, however, you will be given more flexibility with what you can do through your LabVIEW program.
