jgcode
Public Folder for Icon Templates in new Icon Editor
Status: New
I would like a public folder to be used as the default storage for the Icon Editor
OR
At least a public folder it looks to as well as <osdatadir>:\Icon Templates.
The reason for this is I would like to install icon templates as packages using VIPM/OGPB.
The current user-specific location of <osdatadir>:\Icon Templates does not suit this framework for managing packages.
Certified LabVIEW Architect * LabVIEW Champion
4 Comments
AristosQueue (NI)
NI Employee (retired)
There is an update for the LV 2009 icon editor (posted Sept 14, 2009) available here:
http://decibel.ni.com/content/docs/DOC-6301
This update incorporates many suggestions that we got right off the bat from users and fixes a number of reported bugs.
An entire discussion forum exists for discussions about improving/extending the Icon Editor. It can be found here:
http://decibel.ni.com/content/groups/enhanced-icon-editor-2009
jgcode
Thanks for posting AQ. You can see from the history of the discussion forum that I was one of the first to post, and after discussing the above with NI (Th Sa), LAVA and JKI,  I decided to make this a request on the Idea Exchange forum. I also have the upgrade, as I also posted about this problem as well.
I was able to create a successful workaround and made a OGPB package that installs the icons via install scripts, as the default directory is not supported in VIPM nor OGPB.
It would still be cool (and easier) if there was a public folder that was not User/OS dependent - maybe under the LabVIEW directory structure??
Just so I could better manage the icons.
Cheers!!
JG
MichaelAivaliotis
Not sure what you mean by public folder. <osdatadir> is public.
Michael Aivaliotis
VI Shots LLC
jgcode
Hi Michael, thanks for posting!
To clarify, I mean that <osdatadir> is user dependent, meaning when it gets resolved it is set to that current user and not some common folder.
Sorry for the confusion, maybe common is a better term than public when discussing folders???
I am talking of common/public folder e.g. <application> or <vi.lib> whereby any user logged in is accessing the same folder.
Anyways, this makes distributing packages tricky (altho I have the workaround):
a) As the location will be different on each PC
b) <osdatadir> is not supported by OGPB/VIPM
I hope this makes sense
Cheers!!
JG
