User | Kudos |
17 | |
5 | |
4 | |
4 | |
4 |
The Timing palatte is looking bad with all thes gaps. A simple fix would be to fill these holes with useful functions. I'm proposing 3 and attaching 2 from my re-use code. (I may re-create the third later)
Time to XL.vi (Attached): and its inverse, XL to Time.vi
12:00:00.0 AM Jan 0, 1900 is a pretty common epoch (Base Date) for external programs and converting from LabVIEW epoch shows up several times a year on the forums. and Time to excel has a few solutions to threads under its belt. Moreover for analisys against external data from other enviornments you are often using Access, Excel, Lotus... All share the same epoch (and Leap year bug) in their date/time formats. These vi.s have been pretty useful to me although the names may change to avoid (tm) infringements
Time to Time of Day.vi (Attached) has also been in my arsenal and proves both valuable and get on a few threads per year on the forum.
The gaps in the palatte make it a perfect fit
