there is an idea about making labview.ini and other user configs to the corresponding user folder .
I propose to go a step further and make the LabVIEW environment project based, which means that you can define a labview.ini file, VI templates (including standard VI, if you create a new VI), palettes, QuickDrop stuff, etc. inside a project.
E.g. templates are saved in a custom location and linked inside the project. If you do this and start the "New..." dialog, than all your templates inside the project are listed first (below project).
If you do not use this feature in your project, the default files are used (default meaning the way LabVIEW works now).
Marc
CLD
Any idea that has received less than 9 kudos within 9 years after posting will be automatically declined.
