It'd be great to be able to use the "Set current values to default"
invoke method while the program is running to grab the current values
that a program has. As it is now, you have to stop your program and
open another program that references the first program to set the
values to default. This almost completely defeats the purpose of
setting those values programmatically (I might as well go to the File
menu). I'd like to effectively "grab" front panel values and keep them
for the next time the program runs. I know I could do this with file
writing- but it'd be nice to use the invoke node as it seems it should
be used.
Any idea that has received less than 8 kudos within 8 years after posting will be automatically declined.
