User | Kudos |
2 | |
2 | |
2 | |
2 | |
1 |
How many times have you created a control or indicator on the front panel, and have to spend time searching for the new terminal on the block diagram?
Let's put the the new terminal into a floating window tied to the upper right corner of the block diagram. The developer will know exactly where the new terminal(s) will be after creation, and can then drag the terminal to the proper location in the block diagram.
Available in LabVIEW NXG. All new controls and indicators on the front panel are placed in the Unplaced Items Tray. A similar approach is taken for control and indicator terminals on the block diagram.
