Have you ever placed a background image on your front panel to make it look good, but then found that most of the controls and indicators covered everything up?
Ever wish LabVIEW had more appearance customization to make better looking GUIs?
I would like to propose an opacity slider control in the appearance settings tab of front panel object properties. The added setting would not make the entire objects opacity change; ideally the opacity control would only affect the borders and grey space. With this added control users can make better looking user interfaces without having to make custom controls.
Take a look at the difference:
Not Ideal Front Panel with background image and NO Opacity Control
Beautiful Front Panel with background image that you can still see by setting Opacity Control to 50%
Before and After Appearance Settings tab in the Properties Window for a waveform graph:
Currently the only easy way to implement a similar type of setting is go fully transparent by using the tools palette paintbrush tool and setting the color to transparent:
Kudos and share this idea if you want it to happen!
I am sure it is posted somewher but essentially the colorbox should have an alpha channel so that all decorations, plots, controls (anything that uses natice colors) would support trancparency levels. This setting could then just override all the parts of the controls alpha channel or you could do it on a per part basis.
This is a better duplicate of my idea: Independent-Transparency-Settings
Kudos from me!
NI needs a full "Upgrade" of the FP. I've been telling the users and NI this for 10 years, getting good responses from users but NI evidently sees this as a pain in their pocketbook. This will take a significant effort on their part, but will be much more difficult and costly the more years they let it go by. I've learned to program in Adobe Flash (previously Macromedia Flash), and their use of Vector Graphics has a great look and incredibly easy to resize without distortion. Their Fading is in increments of 1 from 0 to 100. Maybe NI should hunt down the original programmers of Flash to upgrade the LabVIEW Front Panel. I believe the Upgrade of the Front Panel will bring in more customers. But I guess that is just my 2 cents worth.
I don't have a degree in industrial design, but the example shown suggests that this would be a very bad idea in some hands... Talk about a cluttered FP and distracting background! Now make it 50% foregound and I am out of words to qualify the GUI... :-)
You must be a registered user to add a comment here. If you've already registered, please log in. If you haven't registered yet, please register and log in.
Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
