User | Kudos |
2 | |
2 | |
2 | |
2 | |
1 |
It would be nice if it was possible to add another 'Reentrant' setting.
This setting would make sure VI A always uses a specific instance, where VI B uses another instance. Sort of a single parent sub-vi.
This would allow for look-up VIs that have a seperate set of data per VI that is calling them.
So you can store some variables that are only valid in a single VI and if another VI is calling the same VI it will be calling a second instance and gets other variables back.
Ton
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
