SanRac
Install Third party executables before starting the LabVIEW application Installation
Status: New
HI
In installer creation, provision should be available for executing any third party installer/executable before starting the LabVIEW application installation.
And
After installing any application developed in LabVIEW, we can see that in Start > Program > <application>, is there any way we can get uninstall option in same menu (Start > Program > <Application uninstall>. (so it remove all the components were installer with the application)
3 Comments
Knight of NI
As for the first: You can already configure an executable to run after the installer. Is there a use case that you have to run it before installing your built app?
parthabe
Trusted Enthusiast
I support this idea reg the 2nd point.
- Partha ( CLD until Oct 2027 🙂 )
muks
Proven Zealot
I dont think where there is need for labview to install something before running itself. If there is such a need then we can install it before hand  itself.Right? But I agree that an option to run 3rd party programs will have its use.
