I've been working with large arrays, and I've found that wire branches are killing my performance. In order to alleviate this I've scattered inplace structures all over, however, the only way I have to access the array size without incurring a copy of the array is to track it separately, and access that size property, this seems pretty wasteful.
I can think of two ways to implement this. The first is to add an array size block to the inplace element structure, this would be awkward to use. So, I suggest the the array size node be made inplace, as mocked up below.
