JimboH
Increase the size of the rearrange cases
Status: New
I think the rearrange cases option would be a little bit more user friendly if the size were a bit bigger.  I don't see why it needs to be so small.
5 Comments
JackDunaway
Trusted Enthusiast
Nearly all of the popups and modal windows need to be resizable. Look around the Idea Exchange and you will find ideas that I and others have requested dealing with resizing windows.
Not being able to resize windows such as these is arguably near the very top of UI snafus in the LabVIEW IDE.
Norbert_B
Proven Zealot
One nice feature could be included in this dialog as well (should be renamed then):
Deleting cases.
Currently, deleting certain cases requires the programmer to select the case, right click and select "Delete This Case". This can be worksome if more than one or two cases should be deleted. Adding a button to delete the selected cases could increase the efficiency of the case structure.
Norbert
Expert: Geometry
PJM_Labview
Great idea of adding a delete case button, but why stop there?
Add a duplicate button as well.
PJM
vipm.io | jki.net
Ravi_Beniwal
Being able to select and move multiple cases would be awesome, when you are trying to regroup cases. And even selecting and sorting a few cases would be great.
JackDunaway
Trusted Enthusiast
According to stackoverflow users, this is currently the #9 worst user interface annoyance.
