Samuel_James
Increase the size of Property Node & Invoke Node
Status: Declined
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
With reference the post in the below link
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Reduce-the-size-of-the-Close-Reference-VI/idi-p/155858...
The idea of decreasing the size of the "close reference" works fine if you wired from a propert or Invoke Node, It won't fit for the references coming out from VIs.
So my idea is to slightly increase the size of "Propery Node" and "Invoke Node" so that it can fit with VIs as well as "Close Reference".
Sample screen is attached Below
If you like this Idea don't forget to give kudos,
Best Regards
SamuelJ
4 Comments
vitoi
LabVIEW real estate is already at a premium. I wouldn't like to see anything that takes up more of the screen.
David S.
NI Employee (retired)
Do you want it to be resized to fit the 4224 or 5335 connector layout? Whichever your choice, you'll be angering a lot of people who like the other one. And you'll still have the problem of it fitting some NI VIs, but not others: for example, many NI driver VIs use 5335, but non-driver VIs tend to gravitate toward 4224. There'll always be a bend in the wire somewhere.
David Staab, CLA
Staff Systems Engineer
wolfkil
Darren
Proven Zealot
Status changed to: Declined
