When loading a VI where some or many of the VI's are missing (like a forum post where the person used 3rd party driver subVI's you don't have or used numerous subVI's and typedef's that they did not bundle into their attachments) you have to click ignore on each subVI as it comes up with the dialog box as it searches for it on your system. If there are only a few such subVI's, it is no big deal. But some people will be missing dozens of VI's, and you have to continually click ignore over and over again until the main VI loads broken.
It would be good if that dialog box had an Ignore All button, so that once you come across the first subVI it can't find, it will ignore it and all other subVI's it can't find. Then the main VI can load in it broken state in just one or two clicks.
