User | Kudos |
3 | |
3 | |
2 | |
2 | |
2 |
some time there is need to display your menu item in application like hyperlinks.
Labview doesnot provide direct solution for this. If you want to customize button control to look like hyperlink, It will add too much code including event structure(please Suggest if anyone have efficient solution) which is not really afforadble if you have multiple hypelinks.
So I suggest that labview should have a built in hyperlink control which will behave like hypelinks when mouse enter and leaves over control and gives Boolean TRUE when pressed. ....
