If I get the sematic of trace memory allocations right, every "Memory Allocate" event for a given handle should be accompanied by a "Memory Free" event somewhen later for the same handle or there is a memory leak. Given that, the trace toolkit desperately needs a feature that highlights all "Memory Allocate" events where no free event exists. Moreover, the event details should not only contain the VI that allocated the memory but also the concrete diagram element. Optimal would be switching to Labview and highlighting the element in the diagram just like the "LabVIEW Compare" tool does.
For now I'm helping myself by
SELECT jo.id
FROM (
SELECT q1.id, c.Beginn
FROM queueTest2 AS q1 LEFT JOIN (
SELECT q1.vi, q1.id AS Beginn, Min(q2.id) AS Ende
FROM queueTest2 AS q1, queueTest2 AS q2
WHERE q1.event='Memory Allocate'
And q2.event='Memory Free'
And q1.id<q2.id
And q1.Details=q2.Details
GROUP BY q1.id, q1.vi) AS c
ON (q1.id=c.Beginn AND q1.Event='Memory Allocate')) AS jo
WHERE isNull(jo.Beginn)
Please note that a Bug in MS Access 2007 reformats this statement on saving it in a way that executing it gives an join expression not supported error. This can be fixed by putting the ON statement into braces again (don't press save before executing).
