 Mads
			 on
		06-24-2009
		03:56 AM
			5 Comments (5 New)
			Mads
			 on
		06-24-2009
		03:56 AM
			5 Comments (5 New)
		Using "Fit control to pane" and the "Scale Object with Pane" options it is now relatively simple to build front panels that scale the way users are used to from other applications - however there is one shortcoming that it is easy to run into: cases where you want a tab and (some of) the controls (a table e.g.) on it to scale with a pane.
Getting the tab to fit and scale is a done deal, but then comes the scaling of the objects on the tab...
The option you have today is to fit the controls on the tab to the pane...however that does not give a proper behaviour because then they grow larger than the tab they are on. Objects that are set to fit and scale to the pane should basically use the tab as their "pane" - not the pane the tab is on.
