User | Kudos |
2 | |
2 | |
2 | |
2 | |
1 |
As mentioned in this comment, the ability to swap two inputs using the control key is a great feature! 🙂
However it is still a bit crippled and is missing a natural extension of the functionality:
It currently only works if both terminals are connected. The feature should be expanded so it also works if only one of the terminals is connected. It would swap the connection to the other terminal in this case.
Available in LabVIEW 2020 and later. The switcheroo tool now works on binary functions with only one input wired.
