User | Kudos |
2 | |
2 | |
2 | |
2 | |
1 |
I would want the option to create anchors in LabVIEW code, these anchors could be used to
These anchors wouldn't change the execution of the code, they are only meant for documentation and should be named. For starters they would only be global in their own VI block diagram, but that could be expanded.
In a document describing the code, you could refer to a specific section (loop, case structure), or you could create a note in the code 'this code starts the following case structure' etc.
Ton
