User | Kudos |
5 | |
4 | |
2 | |
2 | |
2 |
Sometimes you might have a cluster constant, indicator or control on the block diagram or front panel without the labels shown. When you have a large cluster it's not immediately obvious which element you're editing/changing.
When you hover over a SubVI, the connector flashes on the Context Help window and eventually a tooltip appears on the block diagram under the mouse cursor as shown below:
I propose that, just like when you hover over an input/output of a SubVI it does the same to show the element name on clusters on the front panel / block diagram, as follows:
I know it's not the most exciting of suggestions but I think it would be good for usability.
