User | Kudos |
13 | |
7 | |
3 | |
3 | |
3 |
Clean Up Wire function for several wires
I use the clean up wire function very often. Unfortunately this function is limited to a single selected wire. I don’t know if there is a way to clean up several wires at a time without rearrange the other items.
To clean up a single wire you have to hold the mouse pointer above the desired wire and use the short cut menu (select Clean Up Wire).
I would recommend to extend this clean up wire function in a way that allows to select a certain area and use the 'Clean Up Wire' function (similar to the Block Diagram Clean Up function).
Perhaps it possible to create a short cut menu in LabVIEW if several objects were selected. Additionally a short cut for the Diagram Clean Up function could be added.
