JKSH
Allow users to continue working when a build is in progress
Status: New
When a build is in progress (Application Developer or FPGA*), the entire LabVIEW IDE is blocked.
Since some builds can take a long time, it would be far more productive if users could continue working in parallel with the build. Example use cases:
  • Initiate a build for an RT target, then work on code for the PC server
  • Initiate a build for one project, then work on code for another project
To prevent accidents, LabVIEW could reserve all the VIs/libraries that are part of the Build Specification:
  • The call tree of "Startup VIs"
  • The "Always Included" VIs).
*At least the FPGA build only blocks at the preparation stage, but that takes a while too.
Certified LabVIEW Developer
9 Comments
fabric
Kudos (with the "prevent accidents" option).
My workaround: Install 32-bit and 64-bit versions. While building in one version, use the other version to continue development. This workaround is almost certainly dangerous, e.g. editing a shared VI while building could break the build or give unexpected results...
crossrulz
Knight of NI
But if NI does this, I won't have time to sword fight on chairs.
elset191
I definitely have that hanging on my wall.  I need my compile time.
Tim Elsey
Certified LabVIEW Architect
GuenterMueller
My heart also beats for a faster builds. Blocking VIs that are in use for the build is acceptable. Much more I would prefer multi-threaded builds...
egraham
JKSH
Argh, I can't seem to write a post without typos these days. My original is suposed to say "Application Builder", not "Application Developer"
Love it! Perhaps I should retract this idea 😄
+1. The vast majority of PCs are multicore nowadays.
> egraham wrote:
>That's what build servers are for. :smileyhappy:
What if we're a small company with multiple projects and 1 server, and that server is in the middle of a 40-minute compilation of an FPGA bitfile?
tst
Knight of NI Knight of NI
Knight of NI
If you want a solution today, just make a copy of LabVIEW.exe and run it in parallel (or add AllowMultipleInstances=True to the LabVIEW.ini file). Once a VI has been loaded into memory, there should be no conflicts between the different versions, as each has its own copy open (with the obvious caveat that changes you make while editing won't be reflected in the other version until you reload). That said, I have no practical experience with doing this for builds, so there might be some hidden gotchas.
___________________
Try to take over the world!
egraham
We don't create build servers on our own servers. We use Rackspace for build servers. That way you never have to worry about maintaining your own hardware.
d.w.b
You will probably want to copy LabVIEW.ini too (LabVIEW2.ini for LabVIEW2.exe) to get a consistent environment. Run the copy before starting the build so it won't force you to interfere with the other build when it detects what seems to it to be left-over files from a crash and asks you to recover or remove them.
