There are examples of generic ASCII spreadsheet formats that used fixed-width fields and no delimiter. (see for example the XMAP section of XPLOR files for crystallographic electron density, blue part below).
ZYX
XMAP: section #   0 average density=-0.336     sigma= 0.907
       0
-0.97086E+00-0.49927E+00-0.82774E+00-0.13491E+01-0.57034E+00-0.71253E-01
-0.19491E+00 0.61017E+00 0.10064E+01-0.22888E+01-0.94020E+00 0.77451E+00
 0.57539E+00-0.31211E-01-0.27430E+00-0.36526E+00 0.34772E+00 0.81884E+00
-0.19954E+01-0.10117E+01 0.18038E+01 0.19008E+01 0.11886E+00-0.41646E+00
 0.47560E-01 0.48855E+00 0.57606E+00-0.22320E+00-0.12787E+01 0.47590E+00
LabVIEW could easily deal with these sections (i.e. read and write!) using "%12.5e" as format string and an empty string as delimiter. For some reason, an empty string as delimiter does not work for "spreadsheet string to array" and "array to spreadsheet string". If I explicitly wire an empty string to the delimiter input, LabVIEW will silently substutite a tab instead. This is somewhat unexpected, a tab should only be substituted if the input is unwired.
IDEA: An explicit emtpy delimiter string input should be accepted verbatim.
Of course things can go horribly wrong if the field code is variable width, but we need to trust the programmer to be aware and deal with it.
(On a related note, there is still no format code to allow padding the exponent to two digits with zeroes as in the blue parts shown above, however, fortunately the files seem compatible even if I don't edit the exponent to match that pattern)
