asbo
Allow Diagram Disable Structure and Conditional Disable Structure to be replaced with a Case Structure
These two structures can be replaced with each other, but not with a case structure. I can't count how many times I've drafted some code, then want to reuse some or all of the cases selectably at runtime. Changing to a Conditional Disable Structure is halfway there, but then I'd still need to have a project file to define and edit custom symbols, which I often don't.
6 Comments
Darin.K
Trusted Enthusiast
I am not sure if Disable structure means Diagram DS, Conditional DS or both.
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Add-the-ability-to-replace-a-disable-structure-with-a-...
asbo
Guess I was overly specific in my searches. Thanks!
Darin.K
Trusted Enthusiast
I actually had a surprisingly hard time finding it, and I knew it existed (and had even Kudoed it)!
RavensFan
Knight of NI
I thought that idea existed.  But I couldn't find it either.  I probably searched for "diagram disable", but that idea doesn't have the word "diagram" anywhere in it or the comments.  Perhaps I'll add a comment there with "diagram disable" so it can be found more easily next time.
JÞB
Knight of NI
I kudos it by the title!  Laura. I don't care who gets the credit! mark as dupe- either or both- but link the two and poke R&D please.
I know- it's probably unfair, but, I learned the using the "L"-word in a post generates an e-mail (Please, go ahead and edit/PM me not to share this tip again if I am abusing you)
"Should be" isn't "Is" -Jay
srdfrn
NI Employee (retired)
Status changed to: Duplicate
