User | Kudos |
2 | |
2 | |
2 | |
2 | |
1 |
The pane properties dialog is rather limited:
It only shows 4 options:
-Label
-Label Visibility
-Background
-Background alignment
It could also show the following dialog:
So it adds the following properties:
-Origin
-Scroll bar visibility
-Minimum pane size
Currently you have to create some special code to set these options.
Ton
