When building a case structure, the context menu allows you to 'add case after', 'add case before', and 'duplicate case'. This last option ('duplicate case')can save huge amounts of effort in cutting and pasting or re-entering your block diagram.
Unfortunately, these options are not available when entering a flat sequence. Flat sequences do not offer 'duplicate frame', a major omission and also another example of where LabVIEW is inconsistently implemented..
I for one would dearly like the 'duplicate frame' option added to the flat sequence context menu.
Any idea that has received less than 4 kudos within 4 years after posting will be automatically declined.
