User | Kudos |
4 | |
3 | |
2 | |
1 | |
1 |
When you right click on a Call By Reference or a subVI, there is a "Call Setup" item to specify the VI call configuration. For example, the user can specify "Load and retain on first call."
First, there should be a way to access this dialog from the Start Asynchronous Call node and possibly Wait On Asynchronous Call node.
Second, the VI Call Configuration dialog should let the user specify an asynchronous call.
