Amir_Y
Access a sepcific Array Element
Status: Declined
Every array has a property node for "Array Element".
It is referring to a general element in the array (and actually applies to all elements).
It could be nice to have this "Array Element" property for a specific element. "Active Element" property can be added for that (similar to "Active Plot" in XY Graph).
The usage I was thinking is about is getting the position of an element or setting its background color (after casting its reference to a string class). But there is much more to it than these simple examples.
Amir.
2 Comments
AristosQueue (NI)
NI Employee (retired)
This request is impossible to ever support without massively increasing the memory and performance requirements of the array control in a way that LV does not find acceptable.
There is only a single control for drawing all visible elements of the array. We do not create N separate controls for the N elements of the array, thus there is no separate background color that is definable. Instantiating N separate controls every time a new value for the array is set would be unacceptable in terms of performance and memory. The only parts of a control within an array that vary in appearance are those controlled directly by the element value. This is a concious and deliberate design limitation of the array control.
JordanG
Status changed to: Declined
