User | Kudos |
5 | |
4 | |
2 | |
2 | |
2 |
I searched for this Idea but I guess its not posted (If posted please excuse).
While moving the control/indicator/function (Unbundle cluster) outside the loop/structure the wire gets broken but it would be handy if we can move the controls without breaking the wire so reduces re-wiring. This will be very useful when it is implemented with all these. So the idea is to move any wired object without breaking the wire.
When the idea is implemented its easy for clearing
The same for the controls and indicators
I guess this would be more usefull while cleaning the code.
Available in LabVIEW 2017 and later. Dragging items into and out of structures will retain the wiring across the structure border. You can press 'W' during the dragging operation to revert to the old behavior where wiring is not retained.
