When producing a 3D plot with an array containing NaN values, the plot should not interpret these as zero. Rather, these points should be disregarded so that the black lines do not appear. Given the way Labview handles arrays, there is no way to remove these elements given the way that the data is generated and as such it must be left up to the plotting algorithm.
