interfacing fresenius vial syringe pump with rs 232
I am trying to read data from fresenius vial pilot C syringe pump. Getting following error in read operation:
"Timeout expired before operation completed". I have checked the baud rate, parity etc and also the rs 232 cable. Where can be the problem?
Message 1 of 8
(6,413 Views)
You could be sending the wrong command or incorrect termination character(s). What does the manual say? What is the exact string that you are sending? Where is the manual? Does it work with a program such as putty or in MAX?
Message 2 of 8
(6,412 Views)
Manual is attached. I am not able to read through MAX also.
Message 3 of 8
(6,403 Views)
Since you have not answered my question about the exact string you are sending, I can only guess that that you are not sending the correct commands in hex format. Use an U8 array and the Byte Array to String function and calculate the check sum correctly.
Message 4 of 8
(6,401 Views)
I am also trying to use attached program. Put nothing coming in read display.
Message 5 of 8
(6,400 Views)
I am using following string to write:
[02h]\s3PR;1F4014\s[03h]
Message 6 of 8
(6,393 Views)
First of all I need to change to PC mode. For this I am sending through MAX:
02 33 4D4F3B32 C3 03
entire command is in hex format
and I am getting error "Time out expired before operation completed".
RS232 protocol is attached.
regards,
Manu
Message 7 of 8
(6,230 Views)
Please help.
regards,
Manu
Message 8 of 8
(6,229 Views)
