06-27-2014 09:28 AM
Hi there,
I am connecting my Ohaus Scout Pro Scale (Model 6001) to Labview.
My program can only read the data from the scale if I am in the print continuous mode or if I manually press the print button on the scale. But I only want to read measurements every 10 minutes and I don't want to press the button manually.
Therefore I implemented the VISA Write function and I am sending the command P\n (in \-comand). According to the Ohaus manuel this should be the same as pressing pring. But it doesn't work!!!
What am I doing wrong?
Is there someone else out there who is using Ohaus Scales and is able to directly read data from the scale?
Any help would be much appreciated! 🙂
Solved! Go to Solution.
06-27-2014 09:39 AM
06-27-2014 09:41 AM
Check! I have the tick in the right place - '\' Codes Display
06-27-2014 10:30 AM
06-30-2014 04:47 AM
yes - you are my hero!
I am glad to say that this was the solution to my problem! The comunication works now just fine!
Maybe next time I can contribute something more substantual to the forum .:)
Thanks!
