Where do I get ni4882.h file?
Message 1 of 15
(9,639 Views)
Accepted by jgs3
It's part of NI-4882. and assuming you select an appropriate language when you install it. It will be in the same folder as the examples.
Message 2 of 15
(9,636 Views)
My installation completed without error, the utilities are fully functional, I have all of the examples, but the header file (ni4882.h) is nowhere on my machine.
CF
Message 3 of 15
(7,542 Views)
CF
OS ?
Message 4 of 15
(7,501 Views)
Win 7
Objective is to develop C++ app to access the GPIB-USB-HS device.
Search process so far:
Searched for "GPIB-USB-HS drivers".
Brought me to support page for the product which lists these windows driver installers:
Tried each of them.
No luck.
Thanks for any help you can offer.
Charles
Message 5 of 15
(7,498 Views)
@cfedonczak wrote:
Win 7
Tried each of them.
No luck.
Charles
Where did you try looking for the ni-488.h file?
Message 6 of 15
(7,492 Views)
You should really be using VISA so that your application is portable to other controllers or if you switch interfaces such as USB, Ethernet, or RS232. The lower level GPIB functions have not been recommended for years.
Message 7 of 15
(7,483 Views)
Searched for the ni-4882.h file in all directories of my Windows machine.
During each of the installs, the C examples all include this header, but the header file does not get installed on the machine.
Thanks for your interest.
CF
Message 8 of 15
(7,467 Views)
My app is for a temporary test setup, very simple. Read a frequency counter do a little arithmetic, log to a text file.
If I had that header file I could have this done in less time than it would take to read the Visa user's manual. Visa would be overkill for my app.
The cost of using this interface has gotten way out of hand due to the missing header file.
I found a GPIB - USB from another company that has support for C.
Thank you for your interest in my problem.
CF
Message 9 of 15
(7,466 Views)
CF
Your program won't stay simple for long.
Management will want changes.
Message 10 of 15
(7,435 Views)
