PCI-GPIB time out.
I have used 2 kinds PCI-GPIB (one from Agilent, and other from Ni); I have create looping software to acquired the testing data from spectrum Analyzer.
with both computers one with Agilent, and other with Ni PCI GPIB, I have found out that Agilent PCI-GPIB computer continue running looping find forever; but Ni-PCI-GPIB
computer is failed to acquired the data after 37xx loops count.  Is any one have any idea what configuration that I need to change at the driver level to remove this limitation?
One more for notice:  I have used WindowsXP service pack 3 for both computer with Dell Optiplex GX520.  Everything else loading the same driver.
I have duplicated the same failure all the time from Ni-PCI-GPIB computer; it responses null data.
Any suggestion will be appreciated.
(4,171 Views)
What do you mean when you say the computer failed to acquire the data? Does your program produce an error?
Ian K.
Software Developer
Data Ahead AG
(4,145 Views)
I have the same problem the GPIB-Read function lockup after 25 successful reads
(3,025 Views)
Hi labview-PA,
For further troubleshooting, it would be great to know about the device you're are using, any errors you're receiving, and your software configuration.
I also noticed that this is an older thread. You may receive faster support from the NI Community if you create a new thread!
Briana P.
Licensing
Sr SW Engineering Manager | NI R&D
ni.com/support
(3,006 Views)
