what's GPIB command can transfer state file to E5062A from external comtrol(PC)
Deal All
so far, I can use MMEM:TRAN? "D:A.STA" to read the state file on my PC. and now I have two questions.
1. how to save this state file in my PC?
2. what's GPIB command can transfer this state file to E5062A from PC?
about question 2 : I was read E5061-90042.pdf, and read sample program of page 140, and try MMEM:TRAN this command. but still fail.
please advance
Best Regards
Patch
Message 1 of 9
(5,206 Views)
@patchchen wrote:
Deal All
please advance
Best Regards
Patch
What exactly does MMEM:TRAN fail?
Message 2 of 9
(5,198 Views)
You could just save the read data straight to a text file.  That would be the simplest way.
GCentral
Message 3 of 9
(5,195 Views)
Syntax :
MMEMory:TRANsfer <string>,<block>  ----I guess this command can write back to instrument. but alway fail. maybe my parameter is wrong. so I need a correct parameter about <string> and  <block>. if I have a txt of state file in my D:\ of PC.
MMEMory:TRANsfer? <string>  -------------- I can read data to PC and save a txt file. but I cannot confirm the txt file is correct because I cannot write back to instrument and recall to show.
BR
Patch
Message 4 of 9
(5,157 Views)
@patchchen wrote:
Syntax :
BR
Patch
It is in the manual. Read it carefully.
I had to do something like this; I had to write calibration parameters back to an Agilent network analyzer.
Message 5 of 9
(5,154 Views)
to nyc
are you use GPIB command ? or VBA ? or others?
and MMEM:TRAN command is correct ? or others?
or which pages I need to read ?
and you said the manual is E5061-90042.pdf ?
I have spend a lot of time to try and read manual.
could you give me more information?
BR
Patch
Message 6 of 9
(5,152 Views)
You should be asking such instrument specific questions to Keysight.
Message 7 of 9
(5,142 Views)
I was asked before. they told me to read manual and example, test Macro. I had all done.
Message 8 of 9
(5,135 Views)
If you are unable to understand the manual, then you had better tell your manager, so that he can get someone else who can do this project.
Message 9 of 9
(5,124 Views)
