Digital I/O
External Controller Board Software Trigger Examples Help
I am in need of serious help!
For my applications I am using an external controller board connected to my pc via USB. Are there any examples that show how to create a software trigger to start the external controller board operation?
I know the pins on the USB connection are START, STOP, and ABORT but need a good example to go off.
Thank you,
Lawrob
(5,569 Views)
The pins on a USB connection are data+, data-, and power and gnd. I don't understand your comment.
Is this related in any way to NI hardware or software?
(5,562 Views)
Sorry for the confusion, for my application, we can use either RS-232 or USB but based on our connection pinlist one pin (labeled START) is needed to send a trigger to the controller board to start its operation.
I am seeking help for a setting a software trigger in Labview for the START pin for my application.
Lawrob
(5,555 Views)
I don't know the relationship between this physical pin and a RS232/USB port. Any commands you send to this controller should be listed in its documentation.
(5,553 Views)
OK but do you know of a generic example involving using a software trigger?
thanks,
(5,550 Views)
It sounds like you simply need to do a VISA Write. I'm still confused as to your setup though.
(5,548 Views)
