 DeltaJ
			 on
		08-10-2011
		04:00 PM
			3 Comments (3 New)
			DeltaJ
			 on
		08-10-2011
		04:00 PM
			3 Comments (3 New)
		Hi All,
In my post on the LabVIEW board I asked if it was possible to have control over the DIO of a simualted DAQ device. Unfortunately it seems this feature is not available. Once MAX is closed the DIOs run through their own sequences.
If there was a non-blocking way to control a simulated DAQ device through MAX it would permit much simpler prototyping of systems before they need to be deployed to hardware. For example if you want to see how a program responds to a value change simply enter it in the non-blocking MAX UI. Or as in my original case can make an executable useable even if you don't have all the necessary hardware.
I think this feature should only be available for simulated devices.
Thanks for reading - and hopefully voting,
Dave
