NI Home
Cart Cart | Help
You are here:
Announcements
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
Henrik_Volkers
Documentation of all settings of a measuring device as a function of the driver
Status: New
by Active Participant Henrik_Volkers on ‎08-12-2011 08:13 AM
When it comes to documentation of an measurement, you need to report ALL settings of a device that effects that measurement.
From a core memory dump written as a hex string to a XML document.... anything that shows up a difference in the settings that affect the measurement would be fine for documentation.
Something like a big property node readout followed by a format into string .... but make sure not to miss a property.... and a bit more complicated when it comes to signal routing....
A measurement that isn't sufficiently documented is all for naught.
or
Just think of a nasty auditor :smileywink:
It's so easy to make measurements with LabVIEW, please make it easy and consistent to document it.
Example:
A quick measurement setup with the DAQ-assistant/Express fills Gigabytes but after a certain time they are useless because nobody knows how they where taken. A simple checkbox could add all this information in the variant of the waveform. (or TDMS or ...) even if the operator don't have a clue of all the settings that affect his measurements.
Comments
by Active Participant Brad_K on ‎08-12-2011 02:30 PM
Hi Henrik,
Great idea. You can sort of do this today by saving the task (to MAX) and exporting the entire DAQmx configuration to an INI file, but it would be nice to have an easier way to do this that doesn't clutter up MAX and doesn't export the entire configuration.
Brad
About Data Acquisition Idea Exchange
Have an idea for new DAQ hardware or DAQ software features?
  1. Browse by label or search in the Data Acquisition Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see implemented!
Idea Statuses
Top Kudoed Authors
User Kudos Count
2
2
1
1
1
