DIAdem
How can I check whether DIAdem a 32 or 64 bit version?
Hi all,
How can I check in a script whether DIAdem a 32 or 64 bit version? Is there any variable or function?
I need this tcheck to avoid loading 32-Bit COM objects.
gemu
(4,474 Views)
Accepted by topic author gemu
Hi gemu,
The variable you are looking for is APPLICATIONBITNESS. The variable is available in DIAdem 2014 but without documentation. This documentation will be available in DIAdem 2015. The variable is read only and returns a integer (32 or 64)
Hope that helps
Winfried
(4,467 Views)
Hi Winfried,
that helps.
gemu
(4,461 Views)
