07-07-2015 03:23 AM
Hi all,
How can I check in a script whether DIAdem a 32 or 64 bit version? Is there any variable or function?
I need this tcheck to avoid loading 32-Bit COM objects.
gemu
07-07-2015 03:33 AM
Hi gemu,
The variable you are looking for is APPLICATIONBITNESS. The variable is available in DIAdem 2014 but without documentation. This documentation will be available in DIAdem 2015. The variable is read only and returns a integer (32 or 64)
Hope that helps
Winfried
07-07-2015 04:00 AM
Hi Winfried,
that helps.
gemu
