07-01-2015 04:16 PM
Hi all,
I've been working through scripting in DIAdem, and i've encountered a big time sink. Some of the files I work with are upwards of 200MB and these files load within a minute or two however when I save the data it can take 20+ minutes to save. I was wondering if there's any way to speed up this process or if we should change our data aq processes to make smaller data files. The files are Initially Read Only and are then edited and saved under a new name. Let me know if there's anygthing I can do.
Sadie
Solved! Go to Solution.
07-01-2015 06:24 PM
Sadie,
What format are the output files?
Is it saving the files to a network drive, or to a local drive.?
TDM or TDMS both write substantially faster than that. ( I have used files over 2x that size)
Paul
07-02-2015 07:52 AM
I'm using TDMS files, saved onto a network drive.
07-02-2015 08:42 PM
Hi Sadie,
I can think of one way that would take that amount of time to save. That is if the channel type was Text and not numeric. (and it was a long text channel.) Really all channels should be only numeric, with the properties holding any text values, If you had something that was like a text value that varies, it would store best if the values could be made into enumerations, Where the text that corresponded to the number were stored in channel properties. This allows channels to have numbers in them.
Paul
07-03-2015 07:28 AM
I don't have any text channels. All channels are numeric.
07-03-2015 02:09 PM
Hello Sadie,
Could you please try saving the same file to a local hard drive, and timing that vs saving to a network drive.
I assume that saving to the network is slowing this down, but I would like to eliminate other causes by timing the save time to a local hard drive ...
Otmar
07-03-2015 02:16 PM
Otmar,
I just tried saving to the local hard drive and it took less than a minute to save. I do need to save these files onto a network though. Any ideas how to speed up that process?
Sadie
07-04-2015 05:07 PM
Hello Sadie,
I am not sure why writing the file to a network vs. writing it to a local directory has such significant time impact, but one way to work around this is to write the file to your local disk and then copying it to the relevant network location.
I'll ask someone from R&D to check this thread and hopefully they can provide some insight and advice on how to accelerate writing to a network drive ...
Otmar
07-06-2015 01:56 AM - edited 07-06-2015 01:59 AM
Could you please add some additional information:
How is the behavior if you store a TDM file to your share instead of an TDMS file.
07-06-2015 04:09 AM
One effect that may influence is the fac that some time of loading the file might be contained in the save time.
The following script contains some effects.
If the share is connected via DSL the difference in up and downstream speed may influence the result.
(20 seconds is a lot of time for 200 mb tdms file. So it is potentially no local windows share)
Option Explicit dim srcPath : srcPath = "\\server\share\example.tdms" dim targetPath : targetPath = "\\server\share\exampleOut.tdms" data.Root.clear if FileExist(TargetPath) then fileDelete(TargetPath) end if dim txt : txt = "" stopwatchreset 1 call LoadTdmsFileImediately(srcPath) txt = txt & "Load " & stopwatch(1) & " s" & VBCRLF stopwatchreset 1 call SaveTdmsLocalAndMove(targetPath) txt = txt & "Save " & stopwatch(1) & " s" & VBCRLF MsgBox txt sub SaveTdmsLocalAndMove(byVal targetPath) dim fileType : fileType = UCase(right(targetPath, len(targetPath) - instrRev(targetPath, "."))) dim tmpTargetPath : tmpTargetPath = TmpDrv & "\SaveTdmsLocalAndMove." & fileType call DataFileSave(tmpTargetPath, fileType) call DataFileMove(tmpTargetPath, targetPath) end sub function LoadTdmsFileImediately(byval srcFile) dim oldBulkDataLoadingMode : oldBulkDataLoadingMode = BulkDataLoadingMode BulkDataLoadingMode = eBulkDataLoadingImmediately on error resume next DataFileLoad srcFile LoadTdmsFileImediately = err.number on error goto 0 BulkDataLoadingMode = oldBulkDataLoadingMode end function
