DIAdem Idea Exchange
Kevster
Being able to draw a pie chart
Status: Completed
This request was implemented in DIAdem 2019.
Greetings
Walter
As the title says, DIAdem should have the capability to draw simple pie charts in the report section.
8 Comments
teikb
Yes, it really should have!!!
adek
I would also find it very useful.
dietfons
dietfons
Y.Kwon
Pie Chart is not yet implemented in DIAdem 2015 SP1..
For the time being, Polar Axis System could somewhat look like a Pie Chart if designed.
1. Create a channel with 1000+ of same data point for radius data for Polar Axis System.
2. Create channels with incremental data from 0 to 360 for angle data for Polar Axis System.
3. Set the data type of the channels of Polar Axis System to Spikes, not Lines which is the default data type.
4. Zero out all the fonts of the Polar Axis System(labels, etc.).
5. Set the termination point of Scaling of the Polar Axis System with a value higher than the radius by a bit(maybe by 1, ig. if radius is 100, set the termination point as 101)
The below was what I was able to create.
Walter_Rick
NI Employee (retired)
Status changed to: Under Consideration
Hello
Thank you for your request. R&D has read this suggestion and it will be included in feature planning discussions for future DIAdem versions.
Greetings
Walter
Walter_Rick
Status changed to: In Beta
Please have look at the DIAdem 2019 Beta to check the implementation regarding this request.
To participate at the DIAdem Beta Program, please register yourself at ni.com/beta
Greetings
Walter
Walter_Rick
Status changed to: Completed
Greetings
Walter
