BreakPoint
least expensive equipment with LXI
I am trying to learn how to use VB.NET to communicate with a piece of test equipment that implements LXI.
Not for work but as a learning exercise.
The Rigol DS1102Z-E oscilloscope supposedly implements LXI. It sells for $279.
Is there anything that is cheaper?
(1,291 Views)
Why exactly LXI? are you trying to learn to use VISA?
If you search, you may find a few open source projects where they simulate a VISA device using Arduino like this one https://github.com/davidfokkema/arduino-visa-firmware
Santhosh
Soliton Technologies
(1,289 Views)
I know VISA, and I mainly use it with LabVIEW.
LXI doesn't require a GPIB hardware which is pricey if you buy NI.
(1,276 Views)
You could do the same thing with a device that communicates over RS-232.  One option is to get a couple of USB-RS232 devices and a NULL Modem cable and then you can simulate your own device straight in whatever language you want.  You could also skip all hardware and try com0com.  I have not tried this software yet, but I have heard positive results from some people around here.
GCentral
(1,172 Views)
Thanks.
I can do that with Arduinos.
I really want to do LXI.
(1,123 Views)
@psuedonym wrote:
Thanks.
Treat your LXI Device as a VISA Ethernet resource.  See here for starting out with instrumentation.
Then watch this to set up the MAX Configuration.
"Should be" isn't "Is" -Jay
(1,048 Views)
