BreakPoint
Things not to do in LabVIEW
A tounge-in-cheek look at some things the IDE permits but well here's an example:
Ghost.lvclass is a bad idea- hiding objects under loops, making the loop backround invisable more bad ideas.
"Should be" isn't "Is" -Jay
Message 1 of 9
(14,236 Views)
trying to load the snippet searched for the ghost.lvclass. Nowhere to be found....
Message 2 of 9
(14,220 Views)
Call in the Ghost Hunters!
The snippet reminds me of games my associates and I used to play on each other, more like LabVIEW puzzles, where we ran wires under things, had vi's that looked like they were connected to one set of wires but were connected to others, etc. Great at figuring out what not to do, also good for honing some troubleshootings skills.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 3 of 9
(14,201 Views)
Sort of like the obfuscated code link of long ago...
- tbob
Inventor of the WORM Global
Message 4 of 9
(14,165 Views)
15 words ( I promised Mrs Bohrer)
I don't
believe in ghosts,
If Christian does that is
his decision. Haikous
don't rhyme.
Message 5 of 9
(14,153 Views)
Fry bacon.
... and anything else you should not do in the nude.
Ben
Message 6 of 9
(14,136 Views)
@Ben wrote:
Fry bacon.
Ben
OK, certainly don't do in LabVIEW things that should not be done in the nude!  ummmm... (what DOES Ben do in the nude with LabVIEW?) ~~~~~Ben,
Please! don't tell us~~~~~
Message 7 of 9
(14,133 Views)
Frankly, I'd rule out anything that should be done without clothes! Smiley Wink
Which raises the curious situation that LabVIEW should not be used for anything that you should not do in the nude or for anything that you should do in the nude.
So when exactly should we use it?!
Message 8 of 9
(14,101 Views)
The following is ill advised nude or not. Can really hurt you in the brains.
LabVIEW 2012
Message 9 of 9
(14,081 Views)
