BreakPoint
Quiz: Can you get your Add function to look like this?
Even though it's Thursday, today feels like Friday to me. So here you go, a LabVIEW quiz with no practical use whatsoever. 😛 Can you get an Add function to look like this?
This was a regular ol' Add that I dropped from Quick Drop/the palettes. Can anybody figure out what I did to get it to look like this?
(13,432 Views)
Does the answer have something to do with the dynamic data type?
EDIT:
I got it to look the same as yours but I couldn't get it from quick drop.
(13,402 Views)
Steps to reproduce:
  • Drop a waveform constant
  • Drop an Add node
  • Connect the waveform to both inputs of the add node
  • Disconnect the waveform from the add node
  • Drop an numeric constant
  • Connect the numeric to both inputs of the add node (top first)
  • hit Ctrl-Z (undo)
My LabVIEW Ideas
(13,393 Views)
Interesting....
If you wire up that it gives the not-all-wires-connected error. Show context help, click the "detailed help" link for it and doesn't show the "add" help, it goes to the help index 🙂
(13,351 Views)
Okay this thing apparently has bugs all over it.  What is the intent of the error wires?  When are they supposed to be used?  Why do they turn red with X on them?
(13,348 Views)
The error in/out nodes are for waveforms/dynamic data type. You cannot add two waveforms with a different dt for instance. Somewhere in the flags of this node there is probably a 'needs extra nodes' flag which isn't removed all that properly.
Ton
My LabVIEW Ideas
(13,334 Views)
Ton
It doesn't spit out an error when I try that though (it just gives me back an empty waveform).
(13,320 Views)
